Johns Web Site
Date:  4-12-2003
Number of Hours:  4.00
Brief Description:  Disassemble, Debur, Drill, Dimple
Matched drilled assembled aileron. Disassembled, deburred and dimppled. Leading edge holes to SS counter balance were not drilled in assembly due to hardness of the SS. This was to prevent a wondering dril bit from enlarging the pre-punched hole in the alluminum skin. Hole centers were marked with a spring loaded punch and a 3/32 drill used to score the hole. After disassembley a drill press was used to finish drilling the SS counter balance., starting with a 1/16 drill then enlarging to 1/8". Caustion needs to be taken when drilling the harder SS since drill bits dul quickly. On an earily attempt using a 1/8" bit, high drill speed and lack of lubrication caused the tip of the dril bit to over heat. The dril tip melted, welding itself into the SS counter balance. This left a "high speed steel" plug at the exact spot where I needed a 1/8" hole. This was a difficult problem to over come and yeilded less than optimum results.
