L shaped wooden bracket made from 1" by 2" pine is used to hold the skin open to allow work internal to the skin. Installing stiffeners and such. The corner of the bracket is pushed through the elevator skin hinge cut out from the inside of the elevator skin. A wooden dowl is then passed through the bracket corners on the outside of the skin to hold it in place.
