I drove out to Aircraft Spruce to pick up some .032 Al sheet to make the tubing support pieces and the Root Rib Attach Angles (W20-02 & W20-03). The four tubing support pieces (W23-08) were finished and the Root Rib attach angles need the pilot holes drilled.
