Brief Description: Horizontal Stabiliser Continued
So it's been a bit slow coming due to work and other commitments, but post Christmas Eve and Christmas day night shifts still feeling like a zombie I have managed to get some clecos in the horizontal stabilizer frame. All the parts still need cleaning up and some fluting in places but before I get to ahead of myself I wanted to see where holes needed to be drilled and get the trial fit started before I prime. There are two holes to drill in the FWD spar it seems, one each for the center nose ribs. It is also worth noting where the ribs change direction and that only half of the spar flanges are drilled (presumably to prevent twisting as per the rudder and the vertical fin). Also takeing note of the front and rear spars (rear is missing a hole for attachment to the right of center). Now that I have marked it all up and seen the initial fit up I'll be getting to work cleaning up the parts and making sure everything is straight, I'll then hit it with some primer and start pulling some rivets. So far though the alignment is good and very happy with the kit.
