PETER'S WEB SITE
Date:  7-16-2010
Brief Description:  Setting up to leak test RW fuel tank
No pictures but I'll get some when I test the left tank.
Installed the balloon and pressurised the tank. After 15 min the balloon deflated a bit. Could be a slight leak where the balloon is attached, the fuel cap, or the drain valve. I’ll redo and also buy some plastic tubing and leak test with a manometer as well.
