7-02 8-9 match drilled the rudder horn and clecoed together
7-03 test fitted the rudder hinges, I used the number of washers as described, I posted a questions on VAF to see if I need more washers as there is still a little opening.
Caught up on administrative taskes
I got confirmation from VAF that I have to add an extra washer to take the space out of the hinge assembly.
