Peters Web Site
Date:  2-29-2020
Number of Hours:  1.00
Manual Reference:  9225501-LOG-06.031
Brief Description:  3: Cabin Heat Valve
This afternoon I refitted the nose gear shock absorber, and while doing so I noticed that the cabin heat valve doesn't fully close. With the control knob fully depressed there is still a small opening, which is not good. This would be horribly uncomfortable on a hot day, having hot air from the engine coming into the cockpit.
So I decided to fix it.
I removed the fuel pump cover and centre tunnel cover so I could get access to the cusion clamp that holds the cabin heat control cable into place. I then loosened the clamp and readjusted the closed position of the firewall flap.
After checking the operation (all good - it now closes fully) I then reinstalled the covers.
Reinstalled the nose gear shock absorber
Noticed that the cabin heat valve does not fully close
Centre tunnel covers removed to access the cabin heat control cable clamp
