Brief Description: 2: Fuel Flow Meter Installation
After another short burst on the left gear leg weldment, I then started on installation of the "red cube" fuel flow sensor to the firewall.
I attached the engine mount, just to make sure I wasn't going to mount the sensor in a spot that would cause problems later, then set about making another doubler plate, and match drilling it to the firewall, same as earlier today for the oil seperator.
With the doubler plate made up I fitted it with a couple nutplates, then rivetted it to the inside of the firewall. In doing so I also added a small amount of fireproof sealant around all the holes.
Then I bolted up the fuel flow sensor. Another job done :-)
Match drilling my custom fuel flow sensor doubler plate to the firewall
Now the fuel flow sensor is also installed
Fuel flow sensor doubler plate (bottom of pic), shown from the inside
