Peters Web Site
Date:  9-15-2018
Number of Hours:  1.00
Manual Reference:  9225501-LOG-05.075
Brief Description:  1: Copilot Control Stick
Lots of jobs done on Tango Papa Zulu today, starting with the passenger side control stick.
First I shortened the stick by an inch and a half, so it would be the same height as the other side (which I also shortened). After a bit of a smooth over to get rid of burrs, I then threaded on the foam stick grip and the single button top. This side only has the one button, for Push-to-Talk. Don't want my passengers messing with too much.
The passenger side control column isn't the same diameter as the pilot side, so I had to use one of the plastic tube adaptors supplied with the stick grips to get a nice firm fit. All good.
Shortening the passenger side control stick
