The main job completed today was fabrication of a second custom mounting plate, the same as the one I previously made for the Angle of Attack equipment. This one is identical, but mounted on the right hand side of the aircraft.
The fixed, angle bracket, portion is where I have mounted my Manifold Pressure sensor, as well as a 12V relay for the various instrument panel lights.
The swing down portion is where I'll mount the AP-60 Audio Panel, which I've ordered from Aircraft Spruce. This device is simply a six-channel audio mixer which I'll use to mix the stall warning alarm and the AoA audible alarm. These two alarms can then both be fed into the single non-muting input on the Dynon intercom.
Assembling my custom mounting panel on the bench
My new mountng plate installed between sub-panel and firewall
