Peters Web Site
Date:  4-16-2017
Number of Hours:  0.50
Manual Reference:  9225501-LOG-09.001
Brief Description:  1: Nav/Strobe Lights Arrive
After a bit of a mix-up with the initial delivery, my Aveo Engineering wing tip and tail nav/strobe lights finally arrived recently, so today I decided to test them out by connecting up to my 14VDC power supply.
I temporarily connected up the tail nav/strobe light and noted that the white position light draws less than 0.1Amp. All three position (nav) lights together draw about 1.0Amp, and with the strobes going, this peaks at around 2.5Amps.
Pretty happy with that. And they sure are bright!
Wing tip and tail nav/strobe lights
13.9VDC, 0.0Amps. Now that's low power!
White position (nav) LED's energised. The other LED's act as the strobe
