I finished off today by making a start on fitting the bottom rudder fairing. I match drilled the fairing to the rudder and held in place with cleco's. I also put a draw wire in so I could thread the tail light cable.
I then fitted the rudder back onto the empennage, pulled through the tail light cable, and tested to make sure I still had proper movement, and that the wiring didn't get fouled anywhere. All good.
I'll finish this off tomorrow.
Match drilling the fairing to the bottom of the rudder
Here you can see my expanded opening at the bottom eyebolt, plus rubber edge strip to protect wiring
Test fitting, just to make sure the lighting cable doesn't foul anywhere
