Peters Web Site
Date: 3-11-2017
Number of Hours: 1.00
Manual Reference: 9225501-LOG-03.055
Brief Description: 1: Riveting the Rudder Trailing Edge
Having left the trailing edge sealant (glue) to set for two days, now it was time to have a go at setting the double-flush rivets.
Following the instructions to the letter, I first set only every tenth rivet, just to hold everything together. I also did not drive the rivets all the way home. Apparently if you set the rivets completely from one side then you can introduce a bow in the trailing edge, which is not something I want on my control surfaces.
Next I set the remaining rivets, using my back-rivet set, and again, only driving them about half-way home.
I then flipped the rudder over and, using my mushroom rivet set, finished each rivet completely.
The end result .... a beautifully straight edge, with nicely set rivets.
Back riveting the rudder trailing edge
The trailing edge requires the rivets to be set "double-flush"
