Brief Description: 1: Bottom Cowl Induction Air Intake
First up today I finished off the induction air intake by adding the rubber seal between the intake extension and the filtered air box. Nothing difficult here, although I did forget to add washers to the inside sirface when fitting the pop rivets. I might have to revisit this if they end up showing any signs of pulling through the fibreglass airbox.
The ribber seal is fitted
There's now I nece seal between the air intake and the filtered air box
