A couple hours also spent today making up the couple filler pieces that secure the bottom of the bottom cowl. I enlarged the cut-out for the nose gear leg, according to dimensions on the updated set of drawings I received with the new engine mount, then made up the aluminium pieces that secure everything. Nothing difficult.
Marking out the cut-out in the bottom cowl for the nose gear
Making up the filler pieces
This piece holds the back of the bottom cowl together
