Peters Web Site
Date:  2-18-2023
Number of Hours:  1.00
Manual Reference:  9225501-LOG-07.046
Brief Description:  2: Engine Air Filter Box
Further pics of initial work on the air filter box.
With both top plates fixed to the bottom of the fuel servo, and the bottom cowl in place, I adjusted the relative positions so the top plate was aligned with the air scoop. I need to do this because the engine is not in alignment with the centreline of the airframe. It's offset to comensate for engine torque (which, in practice, means very little right ridder is ever required....a very noticeable effect when I flew with my mate in his RV-7).
With the top plate and mounting plate both temporarily installed, I also marked and cit the recess required for the mixture control.
Top plates (x2) fitted to the fuel servo, and bottom cowl fitted
Working out correct alignment of the air filter inlet to the air scoop duct
Cutting the top plate flange to allow unobstructed movement for the mixture control linkage
