Next up today I turned my attention to the mess of wires and plastic tubing inside the cockpit. I routed the pitot tubing through to the space between the main spar bulkhead, and joined it to the two bits of tubing that connect the ADAHRS unit, and Horis PFD. I also labelled each bit of tube (eg: PITOT - SOURCE; PITOT - ADAHRS, and PITOT - HORIS), so that I know which is which later, when it all needs to come apart again.
Routing the pitot tubing through to the spar bulkhead
Connecting the pitot tube to both the ADAHRS and Horis PFD
