Peters Web Site
Date: 12-12-2021
Number of Hours: 4.00
Manual Reference: 9225501-LOG-04.061
Brief Description: 1: Fuel Tank Attach Brackets - Part 1
After a three week absence from aeroplane building, it sure was good to get back in to it today, and I am very pleased with how much I managed to get done, thanks in no small part to helper Nadine Zanol. So much of today's work required a second person to hold bolts from one sied, while I worked on the other.
Anyway, first up today was to get stuck into the fuel tank attach brackets. I spent some time looking at the plans, and something just didn't seem right with the internal support bracket (pictured in the middle of the second photo below). I eventually worked out that I haven't yet installed the bolts that secure the bracket to the longerons. Bugger,.... but no big issue.
Using my right-angle drill from the inside, I match drilled the holes in the bracket to the longerons and skin, then countersunk from the outside. With Nadine as my helper, I then installed and torqued the countersunk bolts.
Job done.
A couple telltale countersunk bolt heads to verify that the bracket is now secured to the longerons.
Internal picture showing the support bracket attached to the longerons
My second set of hands
