Peters Web Site
Date: 10-31-2021
Number of Hours: 2.00
Manual Reference: 9225501-LOG-04.055
Brief Description: 2: Wing Attach Bolts
Gee, a milestone moment has been reached..... I'm about ready to attach the wings!
I spent the remainder of today getting things ready for this momentous event. I took out the seats, removed the console, and pulled out the floor panels. They all need to come out so I can get access to the bolt holes.
I also ground down the two spare wing attach bolts that I'd previously ordered. My aim is to make up a couple bolts that are slightly undersize, and with a tapered end. The standard NAS bolts are so tight a fit that they should only ever be used the once. With my couple undersize bolts I can get the wing attached and proceed with setting up the angle of incidence.
With one bolt ground down on the scotchbrite wheel, and the threads tapered down slightly, I test fitted in one of the spar holes. Yep, it's still a tight fit, but I was able to get it in and out without too much trouble.
I'm now aiming to get the wings attached during my next visit, in three weeks.
Seats, console and floor panels removed
Test fitting one of my sacrificial wing attach bolts
Putting the bolts in the freezer helps get them in the hole easier
