This afternoon I worked on the Supertracks canopy extension rails. I started by bolting down the extension track that sits on top of the rear fuselage. Not easy when you're working by yourself, but I got there.
The Supertracks kit comes with a neat spacer block to help get everything properly aligned. I worked slowly, following the instructions, and ended up finishing the day with the right side track bolted in place. I'll finish this off tomorrow.
This add-on works really well, and provides heaps more access to the baggage area.
The rear canopy guide rail is now 10" longer
Setting up correct spacing of the canopy extension rails
