Peters Web Site
Date: 11-30-2019
Number of Hours: 4.00
Manual Reference: 9225501-LOG-14.004
Brief Description: 2: Nose Wheel
Also today I assembled the front nose wheel. This was relatively simple, with no dramas encountered.
I started by assembling the nose wheel axle. I'll hold off greasing the bearings for now (mainly because I don't have any grease), so have just done the locking nut up finger tight.
Next I prepared the two fairing brackets by smooting all the edges and trimming the wide slot where they slide under the axle bolt washer (second picture, middle of photo).
I then bolted the front wheel into the fork assembly, fitted the fairing brackets, and installed the grease nipple. After checking out my handiwork for a moment, I then installed onto the front gear leg, again just doing up the locking nut finger tight.
No pictures, but also today I did some work on the instrument panel. I filled the flush rivet heads that surround the map box with some resin/flock mix, and sanded back smooth. These rivets will be in the direct line of sight of any passenger I take up, so I want to be as invisible as I can possibly make them. I'm okay with a little "evidence" of a rivet (this is a homebuilt aeroplane after all), but not okay with something glaringly horrible. After my "first pass" filling and sanding, I'm nearly there.
Nose wheel axle assembled
Fairing brackets trimmed and installed
Nose wheel assembly fitted to the front gear leg
