Thought I'd work on the right wing tip today. Unlike the left wing, I've already fitted all the skins to this wing, so fitting the wing tip should be okay.
First step is to attach the aileron and set it in the neutral position. Sounds easy, but took me over an hour.
Aileron attached, and neutral position guide stick fitted
Fitted the neutral position guide to the aileron bellcrank
Adjusted the aileron control rod sevaral times until the trailing edge is aligned
