I thought I'd do some work on the wing tips today, and had intentions to actually fit them. The first step is to attach the ailerons and make sure they're in the neutral position. This is so you can align the trailing edge of the wing tip properly.
I attached the aileron and reset it to the neutral position okay. Took me a little while to get my head around what I was doing as I haven't been here for over a year. Anyway, I got there.
When I went to look at attaching the wing tip, however, I realised I first need the bottom skin rivetted on. Bugger. Oh well, at least I re-learned how to set up the ailerons.
Resetting the left aileron in the neutral position
