Brief Description: 1: Headset Jacks and Master Switch
A couple wiring jobs to start with today. First I finished off the pilot headset jack wiring. Headphone and mike cables run along the underside of the armrest, through special brackets I made and fitted several weeks ago. I also ran in a couple wires from the joystick push-to-talk (PTT) button. The wires hang down a little under the rear end of the arm rest, however if this is a problem then I'll deal with it when fitting the upholstery.
I also ran in wires for the Master switch today as well. Not sure why I didn't do this before now. Anyway, is done now, and tested. All good. The master relay turns on and off with the master switch.
Pilot headset jacks are now done, with PTT wiring also finished
I think that's now all the control wires that I need to run down to the Master and Starter relays
