Peters Web Site
Date:  10-5-2018
Number of Hours:  1.00
Manual Reference:  9225501-LOG-06.013
Brief Description:  1: Firewall Wiring Penetration
Back in to the workshop after 10 days away. While I was gone some more parts were delivered, amongst them a couple of wiring pass-thru kits, so tonight I thought I'd install one in the hole that I'd incorrectly drilled for my throttle cable.
These firewall pass-thru kits are awesome. Made from pressed stainless steel they provide good support for the wiring bundle, plus the kit includes heat resistant sleeve, wrap, and tape, for ensuring you get a good fireproof seal.
I also installed with high temperature RTV sealant to ensure no gases can leak into the cabin.
The stainless steel wiring pass-thru installed next to my prop cable eyeball fitting
The view from the inside. The stainless fitting is nicely rounded to ensure no chaffing of the wiring
With the firesleeve fitted
