Peters Web Site
Date:  9-15-2018
Number of Hours:  3.00
Manual Reference:  9225501-LOG-06.009
Brief Description:  3: Firewall Sensor Block
Next up I fitted the block that houses the oil and fuel pressure sender units. The senders mount remotely to the engine, I'm guessing to reduce the effects of vibration perhaps.
With the sensor block in place I then fitted the oil pressure sensor braided hose, and in doing so realised that I hadn't yet installed the nutplates fore the two cushion clamps. No big deal, I fitted them now.
While working on the firewall I also installed the 24-way earth block that I bought from B&C Specialty Products. The bottom picture below shows it fitted to the aft side of the firewall.
The sensor sender block installed
Oil pressure sensor line installed
24-way earth block on the inside of the firewall
