Lots of jobs done on Tango Papa Zulu today, starting with the passenger side control stick.
First I shortened the stick by an inch and a half, so it would be the same height as the other side (which I also shortened). After a bit of a smooth over to get rid of burrs, I then threaded on the foam stick grip and the single button top. This side only has the one button, for Push-to-Talk. Don't want my passengers messing with too much.
The passenger side control column isn't the same diameter as the pilot side, so I had to use one of the plastic tube adaptors supplied with the stick grips to get a nice firm fit. All good.
