Brief Description: 1: Right Wing Bottom Outboard Skin
Today is to be the day that I close up the right wing for ever. I checked over all dimples and countersinks and decided to add some primer to where countersinking had left bare metal. The outboard skin also overlaps the inboard skin, so I scuffed and primed the inboard skin in this area as well to help stave off the scourge that is corrosion.
After a thorough vacuum of all inside surfaces, and a double check that I'd finished everything that I needed to finish, I then cleco'd the skin onto the wing. Hopefully this will never need to come off again, ever.
Primer where the two bottom skins overlap
Primer to all countersunk holes
The bottom outboard skin cleco'd in place...shall it never come off again
