Peters Web Site
Date: 3-25-2018
Number of Hours: 3.00
Manual Reference: 9225501-LOG-09.010
Brief Description: 2: Leading Edge Landing Lights
After finishing off the left wing, I then started on the same deal for the right wing leading edge landing light.
As I've said before, the second time I do something on this build, it goes so much faster.
I marked out the cut out using the template provided, then, tentatively, put the dremel cutting disk to the wing skin and cut out the opening in the leading edge. I definitely measured twice, measured twice again, and then cut once. After some rough sanding with the cutting tool drill bit, I then smoothed all edges with a file, sandpapaer and scotchbrite pad. The cutout is neat.
I finished the day off by installing the nutplates necessary to hold the light bracket in place inside the wing. No different to the other wing, but still a bugger to do. The outboard rib nutplates are okay, because there's no wing tip in place and I can get to one side very easily. The nutplates on the inboard rib however, well it would be very useful if I had arms that were about two feet longer to make reaching around through lightening holes easier. Anyway, all done now.
Landing light cutout in the right wing
Getting nutplates installed inside the wing is a bit of a task
