Did some more on the stall warning switch tonight after work. Not much, but enough to keep the clock ticking over.
I finished off the small parts that make up the stall warning sub-assembly, and then assembled onto the alodined bracket that holds it all in place in the nose of the wing. Seems to go together nicely.
Preparing the parts that make up the stall warning sub-assembly
Fitted to the nose bracket, ready for installing into the wing (well, once the bracket is primed)
A can and a packet of chips....the staple diet of an aircraft builder. Will keep you going for hours!
