Pete's RV-8 Web Site
Date: 11-24-2009
Number of Hours: 7.00
Brief Description: Finished left tank (baffle and Z brackets)
The last of the time consuming steps on the left fuel tank was finished. As usual, the process took longer than expected. I began by removing every other rivet in the baffle, cleaning the dimple with MEK, dressing the dimple a bit with a countersink deburring tool, dabbing on some proseal and setting the rivet. After all the baffle dimples were complete, I attached the Z brackets sealing each to the baffle surface with a thin coat of proseal.
By the way, I had two of the specified pop rivets snap off with a portion of the shank protrusing above the rivet head. Apparently, this is a common problem based on the Van's Air Force builders forum. Since it was only two rivets on different brackets, I opted to snip the shank off and sealed the rivet heads. After all the brackets were installed, I sealed all the shop heads on the baffle and brackets with proseal.
I sure hope this tank doesn't leak! The only steps left are to install the access plate, the fuel sender, and then leak test.
Wet Setting Rivets
Left Bottom Finished
Left Top Finished
