Pete's RV-8 Web Site
Date:  10-15-2013
Number of Hours:  1.00
Brief Description:  Moved the firewall sensor manifold
I decided to move the sensor manifold higher up on the firewall. I had originally mounted it using the holes and nutplates for the brake fluid reservoir but it wasn't optimum for some of the prefabricated oil and fuel lines. I moved it to the location recommended for RV-7s and mounted it horizontally. I think this will work a little better than the vertical and higher configuration recommended for the RV-8 in the plans.
Sensor Manifold
Sensor Manifold
