Brief Description: Modified and installed dimmer wiring harness
The instrument panel I acquired for installation originally had the dimmer switch for the instrument lights mounted on the left auxiliary panel. I relocated it to the right aux panel next to the LED dimmer and this required lengthening the wiring harness. I spliced in the necessary wires and installed the harness to test the fit. I also installed the harnesses that will tie each instrument light to the dimmer circuit.
