Pete's RV-8 Web Site
Date:  8-27-2011
Number of Hours:  3.00
Brief Description:  Fabricated storage compartment
Today I used the cardboard pattern previously created to fabricate a compartment door from .032 alclad sheet. Once I had the panel fitted it was attached to the mid-cabin cover with a length of piano hinge. It was then necessary to do some final filing and edge deburring/polishing to get a good fit to the switch console flange.
The only task remaining is to acquire and install an appropriate latch. I am currently looking for a flush mounted slide or paddle latch. As usual, it's the little things that take longer than expected. I may have to order a latch on the internet since I am not having much luck at the local hardware outlets and the FBO prices are ridiculous. I had the same problem locating latches for the rear baggage compartment (should have ordered some extra paddle latches at that time).
Hinged Door
Hinged Door
Closed Compartment
Closed Compartment
Inside View
Inside View
