Oil Door I trimmed too much out and had to fill the hole back so that has to cure. I am planning on using flush hardware instead of the wingnut design for a slick look.
Top Cowling horizontal hinges cut to fit and epoxied and riveted into place for better adheason.
Had to trim some of the filler out of the lower cowling to fit the hinge. It exposes some of the foam used during layup process so I have to seal it back in with epoxy.
