This day was spent fixing the error of relay placement and how I wanted the electrical system to work. I ended up haveing to buy some more wire to run from the master relay to the main power distrobution. Both the main power relay and the start solenoid will be mounted next to the battery. The corrections were made and the wires were re-ran to accomidate the new setup. After I got it laid out, I then fixed the wire diagram in the digital format.
