I needed to micro fill the mounts for the brake master cylinders so I made a 15 ml to 3 ml batch of epoxy and used the micro baloons to mix up some micro. I covered the exposed areas on the moiunts and while the micro was still ''wet'' I applied a coat to the right pod to fill some gaps and divets as needed to get the side of the pod flat and aerosmoothed. The pod surfaces were fairly lumpy. I would prefer to have the surfaces flat and smooth to the airflow so that the parasite drag is reduced.
Making Master cylinder mounting bracket Micro over foam to fill dings and smooth phenolic facing
Making Master cylinder mounting bracket Micro over foam to fill dings and smooth sides sanded flat and
