In the last work session, I noticed a slight mis-alignment between the FL-706A&B, and the FL-705. So I formed another FL-706A and re assembled the entire flap to check the alignment of the juncture. The juncture appeard to match correctly with the skin attatched, then I refit the originial FL-706A and noted that all of the holes aligned correctly. This leads me to understand that the juncture is aligned correctly. Build on...
