In this work session I worked on completing the F-706 Fuselage frame. I match drilled the F-728A and F-729A Angles to the respective F-278 & F-729. I also created the additional wiring holes in the adjacent parts to the F-706B. I also created the F-709C Angle from angle stock and bent it to 88 degrees using the 4 in bench vice. I then secured it and match drilled it to the F-730 and F-728. Finally I deburred the parts and and scuffed them in preparation for priming.
