Nate's RV-7 Site
Date:  6-5-2021
Number of Hours:  0.50
Manual Reference:  Sect 8-2
Brief Description:  F-704 Match drilling for AN4 Spacer bolt
Earlier in the work for the F-704 I failed to properly match drill the holes on the F-704 for the AN4 spacer bolts. In this work session I was able to remedy that problem as directed by Van's technical assistance. I purchased a 1/4" reamer and ran it between the holes from the forward (A) to the aft (B) framealigning the holes enough that the AN4-34A bolt was able to be inserted through all four holes with the spacer.
