In this work session, I fluted and deburred the F-708,-710,-711 fuselage frames. Then formed the F-711D, and F-710B angle stock. I think I may have to make another F-711D, as when I match drilled the Angle, it came out 1/32" out of level. I will wait to rivet it in place until later in construction to see how close or far it is out of tolerance as I don't want it to impart twist into the fuselage. Next up is to scuff and prime the parts.
