In this work session, I riveted the left wing aileron brackets together. Following receiving the replacement W-413B-L for the left wing outer bracket. I match drilled, counter sunk, scuffed, and primed the part and then riveted the left wing brackets together. I also countersunk the lower hole on the inner and outer bracket. I then clecoed the brackets in place for riveting.
