I dedicated this work session to mounting the leading edges on the left and the right wing. I started by finishing off the pulled rivets on the left and the right leading edges, then moved on to squeezing all of the rivets along the aft line of the leading edge on the rib flange. I kept wanting to speed up and finish quickly, but I paced myself to check every rivet and get the job done well. Finally I mounted the left and the right upper wing skins, stood back, and marveled at what the last 13 months of labor had yielded.
