In this work session I began riveting the right aileron. this was a mistake, I deviated from the instructions and riveted the aileron skin to the leading edge and the spar together. This is incorrect, the instructions direct you to assemble the leading edge together first, and then rivet the top skins to the leading edge and the spar.
While this break was not advisable, it actually helped me set up and rivet the skins and spar together easily.
