Brief Description: Attach lower wing Spar to wing holder
I finally completed the lower wing attachments to the wing holder. On the inboard side, I clamped the rear spar to the aluminum angle. On the outboard side, I decided to use the attachment bolts to the outer wing rib through a pre drilled tooling hole. Hopefully this works.
