Brief Description: Right Wing Spar and Rib Riveting
In this work session I began riveting the right wing ribs to the main spar. The assembly process call fo the use of AN426 rivets. So I was careful not to damage the machine heads. I accomplished this by using a good amount of tape on the rivet gun head to ensure that the gun was seated properly. I started at the outboard part of the wing spar and worked slowly and only got two ribs done before closing up shop for the day.
