DAVID'S WEB SITE
Evolution
21.2.F.8
NOSE DOOR GAS STRUT
THE FOLLOWING IS DONE AFTER THE NOSE GER HAS BEEN ALIGNED AND BOLTED TO THE ENGINE MOUNT.
1 Install the ball stud into thr bracket.
2 Install the ball tud to the nose gear.
3 Attach the gas strut to the ball stud in the bracket.
4 Insert the gas strutinto the tunnel bove te gear door open/closer ad the upstop brace.
5 Fully extend the nose gear. With the gas strut fully extended hold the tip with the rod end apporx 1 inch past the ball stud.
6 Locate the position of the gas strut attachment in the tummel. Match drill the bracket to the tunnel.
7 Bolt the brackets to the tunnel
8 Attach the gas strut to the ballstuds on the nose gear and on the bracket i the tunnel.
Evolution Home
1207
10 fuselage
11 hyd sys
12 fuel sys
13 brake sys
14 seat/saet belts
15 main door
16 heat/vent/air con
17 baggage door
18 pitot static
19 elec and avionics
20 auto pilot
21 nose gear
3 horizontal stab /
31 ice rain protecti
4 rudder
5 wings
6 flaps
7 aileron
8 landing gear
9 gear doors
duplicate inspection
