ORIENTATION OF THE MAGNETOMETER IS VERY IMPORTANT. FOLLOW THE MANUFACTURES INSTALLATION INSTARUCTIONS.
THE MAGNETOMETER IS MOUNTED ON A SHELF AFT OFF THE AFT PRESSURE BULKHEAD, RIGHT HANDSIDE OFF THE FUSALAGE.
1 Match drill the MAG-3100 magnetometer to the shelf
2 Attach the MEG -3100 tothe shelf using screws, washers, and nuts.
3 Bond the cable tie mounts to the fusalage in a location that will hold the connector in position required by the manufactures instructions, then secure the connector cable. do not kink the cable, ensure all cable bend are larger than 1 " radius.
