I had to remove and reinstall the rudder pedals. They were very tight in the end blocks so I removed them, filed, sanded and used scotch brite on each end and loosen them in the end cap blocks. I applied Aeroshell 5 aviation grease to the ends and also installed the parking brake valve.
