Brief Description: Brake Pedal and Master Cylinder Assy
Attached the pedals to the rudder tubes and brackets. I am using Beringer brakes so I had to assemble the Master Cylinders. This is where doing something outside the plans can get a little confusing. Half the battle was trying to find the right documents to do the assembly. There is a Beringer pdf that has the assembly instructions. It's bascally just a picture with the part numbers and you assemble off of that. No instructions, per se, as seen in Image 3.
